Camshaft Position Sensor - 19463
Murray
108
Oxford
Morning All
I ran a diagnostic scan on the car yesterday afternoon to check for any stored DTC's after fitting my turbo as I wanted to check there were no errors in the system relating to sensors, as Midland Turbo recommended doing this after re-fitting the new turbo. To be honest I was slightly surprised to see that the only stored fault code was: "19463 - Camshaft position sensor - No Signal"
I have searched for information on this but come up short with anything meaningful to me. Does anybody have any knowledge on what may be causing this? I have cleared the code a couple of times now and will re-scan later to see if it has returned but thought I would tap the knowledge of SCN first. Any info would be greatly appreciated. Is it OK to use the car in the mean time as it seems to run perfectly well?
Thanks.
Ifz-jones
Check the wiring and plug connections and after that will be sensor hop this helps
