Guffers's Avatar
Angry Crankshaft sensor?
Hi guys,
Had some trouble with the moter recently, stuttering when starting, and just doesn't feel right.
Hooked it into VAG COM and got this:
VCDS-Lite Version: Release 1.0
Thursday, 30 December 2010, 14:48:18:0
Chassis Type: 6L - Seat Ibiza/Cordoba
Scan: 01,02,03,08,09,15,17,19,25,37,44,46,55,56
Address 01: Engine Labels: 06A-906-032-AJQ.LBL
Controller: 06A 906 032 RP
Component: 1.8I R4/5VT 0010
Coding: 11500
Shop #: WSC 14385
3 Faults Found:
17936 - Camshaft Timing Adj. Bank1 (N205): Open Circuit
P1528 - 35-10 - - - Intermittent
16396 - Bank 1: Camshaft A (Intake): Advance Setpoint not Reached (Over-Retarded)
16500 - Engine Coolant Temp. Sensor (G62): Implausible Signal
Readiness: 0000 0000
Where is the camshaft sensor? I think its the N205.
Open circuit im assuming its gubbed, but read on a Golf forum that the outside temperature can affect the tension of the cambelt, and throw up this fault.
Any ideas welcxome cos I'm stumped!
Hi guys,
Coding: 11500
Shop #: WSC 14385
3 Faults Found:
