Can you fit two or four fingers in…
joely
66
Towcester
… the gap between the wheel arch and a front wheel???? Only asking as last week I replaced the suspension on my LC for an LCR setup, I now how a four finger gap (75mm) where as on the old and most likely shagged LC setup I had a two finger (40mm) gap. Whats the norm?
trebormint
333
Swindon
Can you fit two or four fingers in...
thought was was going to be a very rude question then! :lol:
joely
66
Towcester
two fingers doesnt sound like normal set up.
however of course, no two fingers are the same.
it may settle a bit.
are the springs seated correctly?
Yeah springs are seated correctly, I'm hoping it will settle a bit, i did use new top mounts
vwbassett
Joined the Dark Side
Aug 13, 2007
963
53
Surrey
mine is probably between 2-3 fingers with top mounts and suspension that needs replacing but give it a while to settle.
Mar 29, 2007
1,207
Berkshire
Is this the new measurement for car heights! Makes sense I guess as we use horses to measure the power, so why not hands to measure the car!? ;)
Willie
LCR Track car
Aug 6, 2004
8,939
Sunny Scotland
Take a measurement from the centre f the alloy/hub to the inner of the wheel arch.
I'll do the same with my car and well see what's what
Essexcupra
83
Romford, Essex
It'll probably settle down and will be about three fingers. You're old setup was probably buggered, shocks etc was probably worn thats why it sat lower
