t8337x Feb 25, 2026 5 0 Apr 8, 2026 #1 My car rises up to 107/109 degrees engine oil and when driving hard rises up to 112-113 is that normal Sent from my iPhone using Tapatalk
nd-photo.nl Active Member Mar 6, 2012 5,226 1,135 The Netherlands youtube.com Apr 8, 2026 #2 Which engine?
James_R 🏴🇩🇪🇪🇸 Staff member Moderator Apr 22, 2008 6,392 878 39 Manchester Apr 8, 2026 #3 t8337x said: My car rises up to 107/109 degrees engine oil and when driving hard rises up to 112-113 is that normal Sent from my iPhone using Tapatalk Click to expand... Those figures are nothing out of the ordinary for oil temp. If it exceeds 130 degrees you'll probably get a warning message. Reactions: nd-photo.nl, mty12345 and Mo_86
Bahnstormer_vRS Active Member Oct 28, 2021 340 250 Apr 8, 2026 #4 Always worth checking your oil and coolant levels are correct. I don't mean a gnat's whisker above MIN, but close to MAX. Give the coolers the best level to work with. Guy Sent from my Galaxy S25 Ultra using Tapatalk Reactions: nd-photo.nl and mty12345
nd-photo.nl Active Member Mar 6, 2012 5,226 1,135 The Netherlands youtube.com Apr 9, 2026 #5 Yeps, that pretty normal. My Cupra reaches +100 degrees with normal cruising speeds
