car using oil
Dec 5, 2012
806
Harlow
Catch can it is !
Is there a guide on here to fit one properly
yea there is plenty. it looks abit difficult, especially with all that standard shite pipework in place but its sooo easy to do. its hard to explain on here. ill try and take a pic 2moro.
the catchcan has to have 19mm inlets and outlets aswell as 19 mm internal diameter hose which is oil resistant. any lower and the system wont breath properly. some people have gone smaller with no issues some have issues. IMO its best to replace with the correct size.
its gonna cost you around £60 to remove all the old shitty breather pipework which will fail eventually as heat and oil contamination on these hoses are taking its toll on these cars. this can cause anything from loss of boost/rough running to a smokey exhaust.
I hope this does cure your problem but don't be to disappointed if it doesn't. like I have said previously its every possibility it could be a turbo or piston ring/valve stem seal problem but you may as well rule this out as its the least expensive and very probable it could solve your issues
806
Harlow
Brad are you handy with these kinda things, You seem to know loads about them LOL
well I don't wanna blow my own trumpet but I know a fair bit through experience lol. bits and bobs on mine plus my mate has one and when ever we get a problem or want to upgrade parts we always help eachother out n work on them together so picked it all up along the way
123tud
50
Bridgend South Wales
Loss of boost??? Hmm I put up a thread a while back where if driven hard it seems my boost getting cut around the 4th gear area,
You can hear the turbo spool down for a couple of seconds and then spool up afterwards could this be another clue?
I assumed it was my inlet temps being to high intercooler not being up to the job so the ecu is cutting boost
Dec 5, 2012
806
Harlow
yeaa you can have boost issues and limp mode due to the breather pipework. lumpy idle, cutting out, generally running rough to name a few
123tud
50
Okay! I'll replace the breather work. As you said start from the cheapest. :D
Can you take a few pictures of the catch can for me please?
Thank you for being such a big help :D really appreciate it
Oct 15, 2013
926
Midhurst, West Sussex
Ah that explains it then, I've seen you comment on a few different threads and it normally makes me realise how little I know about these cars when people like yourself Brad who know s**t loads lol :D
123tud
50
Update!!
okay i have replaced the breather pipes! i must say the old ones looked it breathed okay but in grubby condition, this hasnt seemed to do much,
the smoke has changed in a way (may sound daft but here goes)
as before it would puff on pulling off and hitting low boost in second, now it only seems to do it when your coming down the low revs to stop, it is still blue in colour and i am still going through oil fairly quickly,
i shouldnt have done so but i need to take a 200 mile round trip yesterday, when i got to my destination i let the car have a 5 min cool down before cutting the engine, the car sat turned off for around 10 mins and after leaving to head home i pulled in a lay by around 500 yards from the destination to sort a few things out, the needle was reading 90 so it was still at normal temp but there was a stream of smoke coming out, like a blown out candle but much bigger! but this was white in colour
i was in south wales where the weather was around 18 degs a nice and shiney but the destination was horrible and raining, maybe this have effected it but i have no idea :( wheres next gues??
Dec 5, 2012
806
Harlow
Update!!
its a shame, but at least you know its not the breathers not. could be turbo is knackered. or maybe a blown headgasket but a failed headgasket on these engines is highly unlikely. does it show any of the usual headgasket signs? ie creamy oil cap, coolant in the oil or oil in the coolant, overheating etc?
I thought White smoke was head gasket?
not necessarily could be a knackered turbo aswell.
123tud
50
No signs of head gasket failure, i had the coolant flushed around 2 week ago with new thermostat and genuine temp sensor, coolant came out orange, with no sings of oil,
current coolant is clean and pink
OBD readings are about 92 degs and is running near perfect, no drop in coolant either and no Mayo under cap,
I have replaced the cover gasket just peace of mind really..
I think its looking at the turbo, considering it has covered 120k and still on original Turbo, plus the remap
The car its self is perfect, always got power on hand etc, its just that smoke and lose of oil! im going through a liter every 3 weeks
i pulled my Inlet pipe off to and there was only a mist of oil around the pipe, nothing rang alarm bells, can a turbo seal fail on only one side??
