Ok had the car remapped at jabbasport yesterday all successful etc. etc.
Before I left I started the car up and it took a few cranks to start up, I though that its been a hard day on the RR and maybe its just a bit unhappy. Drove it home the 100miles and was fine the whole way.
Tried to start it this morning multiple times and nothing, just turns over without firing up
I have checked the following..
MAFM - fine
All fuses - fine
Fuel pump - does not seem to prime after first click on ignition but is defiantly pumping fuel as I took the line apart in the engine bay and it fires out when trying to turn over.
Spark - Took out the coil pack and put a spark plug in it and turned over. No spark until you try to stop turning it over.
I'm thinking my crank shaft sensor?
Should I remove the Eecu and check for water after yesterday was a wet drive home after having the ecu out at Jabbasport?
Any ideas?
MAFM - fine
All fuses - fine
Any ideas?
