My leon has had an intermittent starting issue for a while.
The full story is below but to cut to the chase there's low power at the fuel pump. Using advice from here I have tried the following:
- new battery (tested today 12.6v)
- new ECM relay (428)
- checked fuse 28
- checked fuel pump relay 409. Clicks fine but unsure what pins to check for volts.
- checked new relay 428. 11.6v at pin 85 and 86. 1ohm at 30 and 87.
- checked fuel pump volts - 1.7v.
The drivers door lock is also temperamental and today it doesn't lock centrally, only using the key and its very laboured, almost sounds dead.
Any ideas and also what pins do I use to check fuel pump relay and relay board?
Full background
First time this happened the recovery guy tapped the ECM relay a few times, fiddles with a few things, it started and didn't happen again for 6 months.
Now it's happened again twice in 2 weeks.
Last week I changed the battery but no luck so got recovered home. The next morning I checked and it was still dead. I scanned with VCDS and it showed the following codes:
17069 - ECM Power Relay Control Circuit (J271): Open Circuit
P0685 - 35-10 - - - Intermittent
16795 - Secondary Air Injection System: Incorrect Flow Detected
P0411 - 35-00
Checked again an hour later and the fuel pump primed and it started.
Today the mrs has got in the car and it won't start again. This time I scanned and it has the same codes above plus:
17925 - Power Supply Relay for ECU (J271 or J363): Electrical Malfunction
P1517 - Intermittent
Any help appreciated as we have one car between us...
- checked fuse 28
Full background
P0411 - 35-00
