Car wont start.
STU3Y
1,271
Kent
Well coolant temp sensor fitted and doesn't seem to have helped at all. Going to wait for vcds to arrive now then try and see if anything stands out.
STU3Y
1,271
Kent
So today I had the starter off and stripped it down to see if it could be causing or adding to the hot start issue.
This is what I found.
Valeo starter (was expecting Bosch)
Edge of starter covered in dry dust
Armature rusted all round & Commutator dirty as expected
I cleaned the rust off with wire brush and wool and rubbed the dirt off too.
The thing that concerned me the most was the damage to the lip on the top edge of the commutator (compare it to the other edge)
I greased all the cogs also, wasn't sure what is the correct grease so used white lithium grease.
Anyway put it all back on, definitely starts better and quieter but still hasn't solved the hot start problem completely.
I measured the cranking speed again and came up at 275 and 297 over 2 attempts whilst cold. Didn't actually measure hot yet.
Scorp
Hi, I just wanted to say, with my Polo 9N I had a hot starting issue that proved to be a faulty temp render.
STU3Y
1,271
Kent
Have also noticed a whistle/squeal that has never been present before, it hard to hear on video but obvious in real life. I am worried its premature wear to my turbo after the tw@ from RAC revved the crap out of it the other day whilst cold and before it even had a chance to lubricate. The noise can be heard right at the end just as the engine has fired up.
www.youtube.com/watch?v=DDHidPyf6Wo
Now think this noise is the starter as got under car whilst girlf started it up and seemed to be coming from the starter motor may explain the damage?
STU3Y
1,271
Kent
Now think this noise is the starter as got under car whilst girlf started it up and seemed to be coming from the starter motor. Might be linked to the damage? Don't know what cause it though.
STU3Y
1,271
Kent
So I now have vcds, but I am a complete novice. My car hasnt failed to start for some time now, however has not really been left for longer than 3 days. Still suffering with the hot start issue, fires instantly from cold but takes a few seconds when up to temp.
How do I begin my investigation using vcds? (Idiots versions please!)
Dan FR
Meth addict. Stage 2+ Yo!
Nov 14, 2013
1,794
8
Caerdydd
Any fault codes? Cranking speed when warm? During the few seconds do it attempt to fire up, or just turn over repeatedly and suddenly instantly come to life? Main thing i would be doing is using VCDS to check all of the engine related sensors are reading accurately and as they should, by looking at the data in the measuring blocks
Dan FR
Nov 14, 2013
1,794
8
Caerdydd
Readings from stone cold are just as useful, it is sometimes the only way to verify if a sensor is accurate. Take temperature sensors, such as the fuel temp sensor. Once the engine is warm, itll be say 60 degrees c. Who's to say thats accurate, it could be 80 degrees c.
Checking readings when the car is stone cold should deliver ambient readings (+ or - a degree or 2) and give you some idea if the sensor is working
STU3Y
1,271
Kent
Had a few fault codes, 2 were due to aftermarket head unit. One for intermittent interior sensors and the other for immobiliser key signal intermittent. I have managed to clear them all at the moment they haven't come back.
It's doesn't really sound like it struggles just takes a couple of rotations. Not sure if it could be the starter still, based on the bit of rim damage in the photos above. I am waiting for a laptop battery to arrive and will then look through all the measuring blocks.
Do I measure the cranking speed as before. Unplug injector loom and turn over whilst watching rpm on vcds or is their a setting that shows it?
STU3Y
1,271
Kent
Some screen shots from vcds, not really sure what the readings should be, however the only one that stands out as being out of place is the bottom photo, block 23 injector switch time deviation. Cylinder 4 is alot lower than all the other for some reason.
STU3Y
1,271
Kent
Someone must have an idea of whether the readings are ok or not, even if they compare to their own?
Dan FR
Nov 14, 2013
1,794
8
Caerdydd
Nothing screaming obvious in there. Injector switch time deviation isn't something i'm familiar with. Is there no max or min rane specified by VCDS? There's some variation, but int he same way you have variation for idle stability/control, where its ranging from -0.75 to + 0.59
STU3Y
1,271
Kent
I know the injector balance works like that but not sure about switch deviation. I am a bit stuck I hoped I would be able to figure it out having bought vcds but may have wasted my money. At the moment it still suffering with hot start and on cold start it runs really lumpy for the first 10 secs then settles. There is always a very strong smell of fumes also
