Crank sensor failure will stop the vehicle starting. Cam sensor failure will just cause it to crank a few times then start.
No one has actually checked this but all said wont be battery cos its turning over well enough.
So more likely to be crank sensor then. so how exactly do I get it checked or check it myself. Give me the dummies versionCrank sensor failure will stop the vehicle starting. Cam sensor failure will just cause it to crank a few times then start.
it tries and tries and tries with no change in effort, normally i would expect it to deteriorate slightly as i have had this before on different car, so I would think the batt is okYou'd be surprised. Imagine a 5 year old trying to kick start a motorcycle. It's turn over, but not enough power to get it going
Will try it next time it doesnt start. I had it on my scooby, where batt was fully charged etc but still wouldnt start. think it was. down to ampage or something, basically the strength required to start rather than power lights etc. Rac mechanic originally said he thought a car not starting call was always going to be the batt but was happy it wasnt this time. I will rule it out for sure next timeIt's just an ideaBut very easily tested. Hook it up to another battery and if it starts first time...you know. If not, then at least you've eliminated another thing.
There's a difference between a flat battery and a battery not putting out the 13.x V it should
I would check fuel system is being primed, taking a fuel pipe off, post fuel filter and seeing if you get a nice squirt of fuel on either ignition prime or cranking of engine.
So if i am right the likely problems could be,
Battery
Fuel filter
Fuel pump
Crank sensor
Camshaft sensor
Glow plugs
Injectors
Question 1:
What order would you recommend checking the suggested faults?
Question 2:
Can anyone tell me the location of each sensor and possibly how to change them
Can you tell me which pipe to disconnect to do the above and which end.
