Hi,
Over the last couple of years I have experienced intermittant problems with my central locking. Whereby the remote will lock all the doors but will not unlock the drivers door so I have to use the key to open the drivers door. The problem only happens in the colder and wetter months. It appears to be an electrical problem as VAG COM has thrown up various codes all relating to other doors (see log below N.B this is the latest log but previous locgs have thrown up codes relating to rear doors too).
The fact that all the doors (at one time or another) have thrown up codes has made me think that the unit that controls the locks may have gotten wet/corroded contacts etc. I had heard that its located under the passenger footwell is this correct? Or will it be water leaking between windows and door cards causing corrion on contacts on the actual locking units.
I am a bit of a loss on it all so any advice would be most appreciated.
Many thanks ,
densil
Address 42: Door Elect, Driver Labels: 1K0-959-701-MAX3.lbl
Part No SW: 1T0 959 701 G HW: 1K0 959 793 M
Component: J386 TUER-SG FT 1130
Revision: 31008001 Serial number: 00000559478503
Coding: 0000688
Shop #: WSC 04941 785 00200
1 Fault Found
00928 - Locking Module for Central Locking; Front Driver Side (F220)
008 - Implausible Signal - Intermittent
Freeze Frame:
Fault Status: 00111000
Fault Priority: 3
Fault Frequency: 36
Reset counter: 58
Mileage: 0 km
Time Indication: 0
Address 52: Door Elect, Pass. Labels: 1K0-959-702-MAX3.lbl
Part No SW: 1T0 959 702 G HW: 1K0 959 792 M
Component: J387 TUER-SG BT 1130
Revision: 31008001 Serial number: 00000018278414
Coding: 0000688
2 Faults Found
00097 - Front Passengers Central Locking (Safe) Motor (V162)
012 - Electrical Fault in Circuit - Intermittent
Freeze Frame:
Fault Status: 00101100
Fault Priority: 3
Fault Frequency: 84
Reset counter: 56
Mileage: 0 km
Time Indication: 0
00929 - Locking Module for Central Locking; Front Passenger Side (F221)
Freeze Frame:
Fault Priority: 3
Fault Frequency: 9
Reset counter: 49
Mileage: 69253 km
Time Indication: 0
Many thanks ,
densil
Coding: 0000688
1 Fault Found
Freeze Frame:
Fault Priority: 3
Fault Frequency: 36
Reset counter: 58
Mileage: 0 km
Time Indication: 0
Coding: 0000688
2 Faults Found
Freeze Frame:
Fault Priority: 3
Fault Frequency: 84
Reset counter: 56
Mileage: 0 km
Time Indication: 0
Freeze Frame:
Fault Priority: 3
Fault Frequency: 9
Reset counter: 49
Mileage: 69253 km
Time Indication: 0
![Furious [:@] [:@]](/forums/styles/seatcupra/oldforumsmileys/furious.gif)
