you lock the car using the keyfob or key - it locks the doors.
Thats all there is to it - if yours doesnt do that - then something is broken!
In some cases, 1 press will open all doors.
In others,
1 press should open drivers door, another press will unlock other doors.
If you need to press more than that - then you need a new battery, or stand closer to the car.
In others,
For interest, is there a reason as to why there are more than one option...?
It can be changed in VAG-COM, so some cars have been changed to suit the owners personal preferences. I have changed mine so it's one press to unlock all doors.
No. If it's coded properly it will work. If it's not, it wont. There is no middle ground with this so it either works or doesn't.
