dubburke Jun 3, 2019 6 1 Sep 2, 2019 #1 I have a 2005 130 tdi sport, which is an Irish import, the clocks are still in Km. Is it possible to change to a set in miles and be a straight swap?
R3k1355 Active Member Oct 30, 2014 1,907 293 Yorkshire Sep 2, 2019 #2 You could change the entire binnacle fairly easily, needs properly coding tho as the immobiliser is built into it.
dubburke Jun 3, 2019 6 1 Sep 2, 2019 #3 R3k1355 said: You could change the entire binnacle fairly easily, needs properly coding tho as the immobiliser is built into it. Click to expand... I have had the ECU remapped and immobiliser removed, so I can use any key without coding
