changing engine compression bam ????
Muttley
Catch that diesel!
Mar 17, 2006
4,987
31
North Kent
AMK and BAM engines
Compression ratio 9½:1
Bore x stroke 81x86.4 mm
Increasing bore will increase CR if everything else is left equal.
By my rough calculations, if you increase the bore to 83mm, swept volume goes up to 467.5cc, (engine becomes 1870cc from 1800) and CR goes up to 9.9:1. That's quite an increase.
But in a turbocharged engine the effective compression ratio is also affected by the boost.
I'm pretty certain you'll need a new map in the ECU . . . :)
paul-murphys
efr 6758 here i come
I'm thinking of changing compression as want to go big turbo in future but also changing engine to a 1900cc by using 83mm pistons which I believe are a good upgrade for engine. Does anyone know benafits of changing from 9.1 to and 8.5.1 as can get pistons with 8.5.1 straight away or have to wait if want 9.1 for pistons to be machined.
Willie
LCR Track car
Aug 6, 2004
8,939
Sunny Scotland
How about 9.25.1 heard that's good for low down power
If I were you I'd try and limit the low down power and sacrifice this for more top end power unless your planning on running a multi stage boost controller, sticky tyres, differential and uprated engine mounts to allow you to get this power to the road
paul-murphys
How much power would I lose low down and I though hybrid turbos run out of puff at 6.6 k guy who mapping was talking about altering the rev range so the car can rev higher he said 7500 is easy achiavable to have my peak power and yh updated engine mounts and after getting same diff as you. So what compression think should go for?
Willie
LCR Track car
Aug 6, 2004
8,939
Sunny Scotland
Sorry Paul I don't have the foggiest about compression.
All I know is the AMK/BAM OEM compression is 9.5:1
This is from the OEM spec sheets for the engine
Dan1720v
1,928
Street, Somerset
ah mines an APX bottom end..
Compression i'd try to keep at 9:1. or as close as possible.
You can go 8.5:1 pistons then check the squish and work out how much you need/can skim off the head.
BBoy82
Dan the compressor man...
Oct 25, 2008
293
East Northants
Have you tried talking to the supplier of the turbo? If you run too high a compression ratio with higher boost, you risk 'pinking' or pre-detonation. IMO theres a reason you cant get those pistons off the shelf...
paul-murphys
I have to get them machined to that size as only go up to 82 and I want 83 also was doing a
deal on piston rod combo and only had pistons with those 2 compression ratios. Will just wait out and see what can offer me and how long will take to make pistons in size 83 mm. Will keep 9.1 cr
