Pads due a change soon as I found out to day and wondered what the trick was with this is as a mate of mine was saying you need to screw the piston back into the cylinder with some kinda special tool instead of the traditional 'just push it back in'. to complicate things further you need to undo the bleed nipple a bit and attach bleeding kit so when you push piston back in dirt doesn't interupt the ABS solenoid valves???
anyone be of any help on how to go about changing rear pads on the Leon Cupra? Managed to do the front no problem at all but these rears sound a bit OTT.
