Cheap EBay LC exhaust manifold
carlossus
153
Bournemouth
Hi all,
Anyone have experience (rather than just opinion please) of these..?
eBay number 260873628339
Mine cracked (or crack opened up) when I swapped the turbo, and at 120k miles I'm not going to spend £270 on an oem if I can help it.
The other option is the cast aftermarket ones for about the same price.
TIA.
carlossus
153
Bournemouth
this one won't fit lc lee its for longitute engine already ask the guy ,
Damn, you're right. I've been looking at so many of these I assumed this was transverse. So the question changes to whether anyone has used one of these...
http://www.ebay.co.uk/itm/VW-GOLF-1...CarParts_SM&hash=item2c5d8f213a#ht_688wt_1037
there are loads of lc breaking on fleebay why not ask for a manifold
Mine was fine before it broke, the eBay ones are all high mileage like mine was and I've been bitten too many times to risk it on a 2nd hand one.
Lee, your crack (!?) is same as mine pretty much.
seatcupramad23
kc4even23
Sep 7, 2009
3,239
birmingham
toyosport one will fit but be careful would those not too sure on build quality to bo honest , in regards 2nd manifold high mielage or not they can crack with low mielage ones i would rather get a 2nd one with no cracks than toyosprort one they do many things good but somethings stick with oem made
carlossus
153
Bournemouth
I think I'm going to try the cheap Toyo cast one. Cracks are mostly caused by thermal cycling and fatigue from vibration so older is higher risk IMO.
Thanks, I'll try and remember to finish the thread with a review once fitted (or sent back).
carlossus
153
Bournemouth
So, the manifold arrived and I fitted it.
Sorry for lack of photos!
Manifold:
Looks like it's worth the £99 I paid. Little finishing to remove flashing where not necessary, which is fine.
No internal flow guides like the standard manifold. This worries me a bit. As you look into the exit of the oem unit. you can see it is profiled to guide the gas into the turbo. With the Toyo one it is just a void, all cylinders feed into an unflowed volume.
Mating surfaces are milled flat, but finish is rougher than oem. On mine there were a couple of dinks at the edges during handling that I filed off before fitting. No biggie. Seems flat enough.
Internal volume is significantly larger than oem. Each pipe is quite a bit wider as it leaves the head. More on this below.
The mating flat that bolts to the turbo is significantly different to oem. It is much thicker which has some consequences.
1. The oem bolts aren't long enough. You'll need 3x M10 x 70 (rated 8.8 or higher, I used 10.9)
2. The bolt nearest the head MUST BE DROPPED INTO THE MANIFOLD BEFORE IT IS BOLTED TO THE HEAD. I didn't and had to unbolt the manifold to fit it (which was a total c**t).
By far the biggest (short term) issue with this manifold is that the increased pipe diameters has reduced the space around the mounting nuts on the top row to such an extent that NO STANDARD TOOLS ARE USABLE. Sockets wont go on, ring spanner wont go on and an open ender wont turn 60 degrees so it not usable. I had to modify a 12mm ring spanner - ground it's width to about 3mm and reduced the annular width around the ring as much as I dare (to about 2mm). Then bend the neck just above the ring to 45 degrees. Then leave off the normal washers. It's the only way. Even then the torque you can get onto the top row is questionable. I spent 2 hours bolting on just the manifold a few degrees at a time. Then had to undo it to fit the M10 turbo bolt!
USE NEW BOLTS AND GASKETS as you only want to do this once!
The turbo and exhaust lined up just fine one it was in place.
I've driven a few dozen miles today, most were slow (newborn in back), but it seems fine. Difficult to comment on performance as at the same time I fitted a refurbished turbo and a 3" Dp + decat. But the overall package is bloody quick for a stg1 LC tune. Part throttle is lovely and WOT likewise. Boost kicks in hard from 2.2k and showed no sign of giving up at 6k.
If this manifold lasts for 30k miles then it will be worth the saving. If it fails before that then I'll be back to report.
