Climate Control/ Heater Problem
EB20VT
287
West Yorkshire
Hi
I seem to be having a problem with the heating in my car (not good at this time of year). The air coming from the vents doesn't get warm no matter what temp i set it to whilst at a standstill, as i start to drive it becomes warmer but when i slow down it gets colder. If i'm on the motorway though it will get up to a decent temp and stay like that.
Could my aircon need a service/ regassing?
Or could it be the heater matrix?
ian_cupra
fair enough,
(off topic) you got cod5 yet?? not seen you on it yet
EB20VT
287
West Yorkshire
No mate i've not got it, my HDTV is bust at the moment so i'm having to make do with a 20 inch and i can't stand standard def gaming now! I should be getting a new TV within the next couple of week, i still might forfeit COD 5 though and wait for 6 and in the meantime clock up a few hours on Killzone when it comes out!
azzy d
mine started with heaters doing that pal and now its at ted johnsons, cause the engines overheatiing and the coolant and water keeps disappearing and theres a constant big build up off pressure. they carnt tell me what the problem is yet thou as my coolant hose pipe has a big split in it (there not sure if thats the problem or if its because of another fault which then in turn has caused the pipe to split) so they need t get that part in and fix it on before they can find out if theres any major damage eg head gasket going.
heres hoping its just the pipe thats gone but i dont think it will be somehow
EB20VT
287
West Yorkshire
That doesn't sound good, mine'll be going to Ted Johnsons for its aircon service. I hope that'll sort it, if not they might have an idea after they finished with yours.
Nick_A
Not a newie really
Oct 2, 2007
55
Hertfordshire
Mine did something similar, never went very cold with air con on in summer and never really went very warm either.
Trip to local garage for a regass of the system and its sorted. Saying it may need regassing prehaps.
Nath.
The Gentlemans Express
Jan 1, 2006
8,619
16
EASTLEIGH, HAMPSHIRE
It's nothing to do with the Refrigeration gas,this gas is for cooling not heating. My first guess would be that your thermostat is stuck open.
Nath.
Jan 1, 2006
8,619
16
If the thermostat is stuck open the temp needle will show you that the water takes a lot longer to warm up and once warm the water temp will not be stable
EB20VT
287
West Yorkshire
I don't think its the thermostat in that case, it still warms up at the same rate it always has and stays stable. Cheers anyway, at least its ruled that out.
azzy d
well since ted johnsons couldnt get me a hose pipe that i needed (not there fault its seats) found a place were they made them, so got ted's to take it off 4 me and i got one made (excat copy). thats been fitted on and the cars still doing the same. looks like its the head gasket :censored: :censored: :censored: ( 6 people have had a look and have said this).. looks like christmas is canceled for me, any1 any ideas of how much am looking at or know any places round the barnsley area that can do the head. been told need some special tools or what not, to get timing belt off etc
thanks
EB20VT
287
West Yorkshire
You could guve JBS a ring they are only in Chesterfield, they might be able to do it, and i should imagine it'll be cheaper than SEAT.
