Gazza_24
363
Hi Guys,
Hopefully someone can shed some light on this for me.
Since the weather has turned cold my climate control temp settings have rarely been set below 19* but tonight I was feeling a little sweaty and moist so I turned it down to 16* but for some reason it was still pumping out hot air, even after leaving it set at that for 10 mins it continued to blow fairly warm air out. The only way I can get it to blow cooler air out is to stick it on low but then it blows out ice cold air, any ideas why this is?
Any suggestions will be appreciated ;)
Cheers.
Gaz......
worryingly my old one used to tempermentally do this, have you tried turning it on and off lol please excuse the vastness of my climate control knowledge :D
When you turned it down to 16 was you cabin temperature below 16 degrees ?
If it was colder in the cabin then it will blow out hot air and then to try and keep the cabin temperture at the set level, it will have to keep blwwing warm air if it is a cold out side.
