Clips On Forge FMIC
tris
The Daddy
Feb 25, 2005
3,493
Kent & Track Days
www.leoncupra.net
Will be fitting my Forge FMIC on Friday and a few people have said to me about changing the clips to stainless steal due to the alloy ones cutting into the pipes or popping off but they do have a R if that matters
Has anyone else done this or will the ones that came with it be fine as the last thing I want is to have pipes pop off while on track like a few people on here have had
Thoughts welcome
m0rk
sarcasm comes free
27,787
33
Clanfield, UK
can't see how a steel clip would cause it to slip... more likely they used a screwdriver to do the pipes up, or didn't fit it right
Willie
LCR Track car
Aug 6, 2004
8,939
Sunny Scotland
It splitting might be due to improper fitting. If you tightened the clip ontop of the rib then you will split the hose. Best off taking a socket, with a few extensions and ratchet as a popped hose will spoil your day. It any easy fix.
1 tip if I may, make sure your clip tightening bolts are easily accessable;)
