gazcuprablk
my 300+ death box :)
Mar 31, 2006
854
south wales
hey all the clocks in my car arent up2 much and some1 who previously owned it took the engine managment bulb out, and also now and again the lights behind the clocks go on and off as if im going over rough ground when i aint! so i have new clocks to go in and have use of a vag com just need to realign them but was told its not the same as changing the ecu.
i have asked in the vag-com section but ive had no reply there so im going to try here and if anyone knows as im sure someone on here done it the other day let me know as its doin my head in now lol
cheers gaz
when my clocks went wrong and i had them changed the immobiliser had to be coded, you can sort the mileage with vag com i believe.
not sure how you'd do them on vagcom if you can, mine got coded at the dealers as apparently thats the only place that can do it or i was told this anyway by the garage that did it.
