clocks
ather`s
EXEO Sport & mk2 IBIZA
Sep 7, 2008
2,059
mansfield, notts
can anyone tell me if a set of mk2 gti clocks will work in a 1.4? i know that they will physically fit but unsure if the wiring will be the same and work all the gauge`s. i also know that the trip computer obviously wont work either. cheers guys.
Fl@pper
Jun 19, 2001
12,368
25
Gloucester
to save search bringing up a list of threads saying 'use search'
http://www.seatcupra.net/forums/showthread.php?t=197896&highlight=gti+speedo
http://www.seatcupra.net/forums/showthread.php?t=181338&highlight=gti+speedo
http://www.seatcupra.net/forums/showthread.php?t=139986&highlight=gti+speedo
general concensus so far is they plug straight in but if you get too far apart on the year you will have to manually check he wires for the correct earthing
if you can get an early 95ish gti speedo (orange/black iirc) you shouldnt have many issues
Brummy
Nazi Moderator-Bot
Mar 6, 2005
4,275
Moved to the DarkSide
yes, they can/do.. only thing you might have to do (I did) was remove the indicator bulb from the unit as it buzzes.. other than that should be fine
