today I changed my front brake pads on the LCR for the Ferrodos.
On the drivers side I now get the reverse/forward 'clonk', which I'm not too worried about after searching on here...
But the passenger side makes a 'clonk' when I'm turning right (not left!)
The only problem I had when changing the pads was that the 'inner' pad on the near-side was a bugger to get out!
it wasnt a problem with the lip on the disk, or sticking pistons, it just needed a lot of 'encouragement' to get it out!!
is it likely that the pad is just a little too large for the caliper and sticking? I'm not sure I'd be able to get the new pad out again easily? I did put copper grease on the back of the pad but I think its catching on the top/bottom.]
do you think it will sort itself out as I use the brakes more? why does it only happen when i'm turning?!
cheers
Mike
cheers
Mike
