i believe the drop links for the lcr are diffrent from the cupra because of the camber adjuster.. you could try the stealers or ebay if your car is lowerd then you will need the shorter drop links..
it is possible it could/maybee be the rubber in the top mount needs replacing?? both are easy jobs though and if it is either one of these, then would be best to replace both sides at same time...
