clutch fitting tips
exsaxoboy!
125
sutton BRUM
Clutch needs to be replaced, i can either pay 100 quid to get it done, or have a bash myself. Any body know of a guide any where, or have any good tips? im fairly good with the tools, but never done a clutch before.
Jonzy
Clutches are one of those shitty jobs id rather pay someone todo.... speaking from experience.
Tony 156
468
Thatcham
i agree, when having all my gearbox work done i had a look when it was apart, didnt look pretty, alot come off the engine and ancilleries to get it all apart. plus 100 quid is a good price.
m0rk
sarcasm comes free
27,787
33
Clanfield, UK
Agree ^^
I found it rewarding to do, and it was a huge leap of faith (haynes to the rescue) but it's pretty straight forward (and not too much in the way of fiddley spaces)
along the lines of:
Drain gearbox oil
unbolt driveshafts (at g/box end)
remove start motor
undo all the bolts that hold it onto the block
replace clutch (remember to use a centering tool)
refit gearbox (lol)
and the starter
and all the other bits you took off to do the above removing
curse at VW designers for putting the gearbox oil top up hole in such a stupid place.
exsaxoboy!
125
sutton BRUM
Didnt realise you would have to drain the gear box oil, thought it would be sealed away from the clutch etc. Are the centering tools the same for all cars, or do you get different sizes etc for different cars? I turned a bit of steel at work that slides into the splined clutch bore, but im not sure if it would fit the fly wheel bore.
Where would i get the correct tool from?
Time isnt a problem, just worried about getting stuck halfway througth, and having half my internals on the floor!
m0rk
sarcasm comes free
27,787
33
Clanfield, UK
draining gearbox oil is easy. I guess it makes it lighter (every kilo helps)
centering tool 'kit' was bought from halfords
all said & done. for £100 - I would let someone else do it. But it is good
cupra_matt
Audi Technician
Dec 15, 2004
1,362
Carlisle
I did mine a couple of weeks ago.
Iam a VW/Audi/Seat technician and i found it a fiddle, gear boxes are generally easy (in fact ive done 2 touran's today). Alot of crap on the Cupra to remove before wiggling the box out, and the engine needs to be held towards the front of the car, i used the jack out the back of my car, against the subframe and engine block.. Not a easy job for you to do, especially if you haven't got a ramp. Personally i wouldn't let anyone else exept a select few work on my car but i would have payed to get that done. Twas a sh*t
TTS Roadsport
VAG specialists
Apr 24, 2006
229
Bedford
www.ttsroadsport.com
I agree with you. Its a pain to do Ibiza gearboxes. Comes with the job:cry:
It is much easier to drop the subframe slightly. This saves a good hour gettin it in and out.[B)]
Ive never had to drain the oil when doing a box tho?!
I would gladly pay someone £100 to do it for me. Would be nice to sit and watch for once!
