you must clamp the rubber host that feeds the slave cylinder so the resovoir doesnt run dry but dont damage it,using a fine screw driver pick out the little steel u shaped clamp so you can remove the pipe then simply unbolt old/fit new replace the pipe refitting clip remove your clamp open the bleed nipple and get someone to pump the clutch pedal to expell any air in system whilst you keep your finger over the nipple to prevent air been sucked back in.with the pedal to the floor lock the nipple and test it making sure you keep an eye on fluid level!
pics would help
pics would help
