clutch slipping..but only in 6th?
Nov 7, 2009
858
hi guys, as sed above, my clutch seems like its slipping..but ony in 6th gear and not a sighn of it doin it in any other?? can this happen? seems strange. jus as i was about to buy a wmi kit and a exhasust manifold aswell, thats gone down the sh*t pan :(. any ideas??
Jun 16, 2008
516
mines started in the same way.
only 5th/6th at first - the higher gears have more load
it only gets worse after that im afraid.
Mr Cellotape
AKA Mr Ribbed
May 9, 2006
1,283
Warwickshire once.
In cold conditions you may find your car is running slighlty more power than usual, the 6th gear being the one that puts the biggest load onto the engine may be slighlty damp/cold and therefore slip due to the extra power/lower grip.
I suggest using the other 5 gears to move upto a speed were it is suitable to use 6th.
Nov 7, 2009
858
mines already running 348ftlb of torque anyway so i guess i do need a new clutch.. but the tdi clutch is rated the same as the lcr clutch anyway
Nov 7, 2009
858
Do i need to change the flywheel wen changing the clutch? As iv jus priced 1 up from gsf and they are 250quid plus the dredded VAT! Can i jus change the clutch and the slave cylinder and it wil be fine?
Nov 7, 2009
858
Well mine is at 90k now. The flywheel is expensive man lol. Il shop around to see what prices i can get. Iv already bought my clutch. Cant believe the flywheel is so dear. Cheers for the info
Nov 7, 2009
858
Im goin for a oem 1 as im realy running silly power. Il ask my mechanic to have a look at my flywheel and see if it needs changin. Any 1 else changed the clutch on a stage 2 without changin the flywheel?
OFI
350
Salisbury
For a Leon Cupra 2001 could anyone point me towards the LUK/GSF replacement parts that i've seen mentioned in other threads? (part numbers?)
I've looked on EuroCarParts and GSF and I can't be sure i'm seeing the right parts (DMF is £330+ on ECP) as people have been saying lower prices.
Garage have quoted me ~£1000 all in to have clutch and DMF done and on a car of this age and value that's just absurd.
Are these DMFs really that bad? Are they easy to diagnose as being badly worn once the 'box is off?
To the threadstarter mine showed a slight sign of slip in 6th then one week later it suddenly died completely.
Not like the old Primera, had a years warning for that!
vwtrellis
Mine has just started slipping in 6th. Luckily I'm a mechanic so I can do it myself still annoying though. Any good garage should have a guide for movement allowance in the flywheel. Mind out as most garages say it needs a flywheel just to get a extra sale. Been a mechanic for 2 years now done about 30 vw clutchs and only ever fitted about 2 flywheels. We keep all the parts we have replaced for the customer to see so ask for them to keep it and I'll get the movement numbers up so you can personally check it and make sure you haven't been done!
OFI
350
Salisbury
Thanks for that, that's very good to know.
