Hello! I've buy a kw v1 kit, but everybody tell me that i must change the anti-roll bar because under 4cm of lowering, i will have problems. The solutions is to change the bar, but do you know another way? Thanks!
As said with a 40mm drop you should be ok but adjustable drop links are also an option.
http://www.dpmperformance.co.uk/vma...i-19tdi-cupra-19tdi-fr-19tdi-1199-p-2510.html
Damian @ DPM Performance
If you fit the adjustable drop links then you won't need the uprated ARB.
I'd say you need to make the droplinks shorter......and the V-maxx ones are longer
I bought those V-maxx ones and had to modify them as there longer than a standard droplink....and there only adjustable to make them even longer pushing the ARB even closer to the DS.
You'll need to see what length you need first.
I lowered my LC 50mm (Wietec)and had no issues with the drive shaft hitting the ARB as has Dione J.
