coilovers
aterro
Banana Bomber
Oct 28, 2009
118
hello
right fitting my coilovers.
have new top mounts.
so its pretty much unbolt, then fit new stuff.
no spring compression needed for taking off?
then what will i need..
camber alignment?
tracking?
laser alignment?
is laser alignment the same as camber allignment?
how much am i expected to pay for this?
thanks people
truCido
Race Lupo in progress...
Dec 11, 2003
2,938
Bristol
www.vagowners.co.uk
correct you wont need spring compressors as you wont need to take the old stuff apart to get the top mounts off. As long as the new ones come with everything you need that is :) I've heard of some not coming with all the bits but most should
You will want a full 4 wheel alignment done. This is camber and toe, which area do you live in?
aterro
Banana Bomber
Oct 28, 2009
118
leicestershire im from.
so do i just ask for laser wheel alignment all round?
wont need to ask for tracking or camber?
truCido
Dec 11, 2003
2,938
Bristol
www.vagowners.co.uk
same thing, you need the tracking and camber done. Which is sometimes called a 4 wheel alignment amongst other things! However make sure its done by a proper place and not somewhere like Kwik Fit, Q (or whatever its called) etc.
aterro
Banana Bomber
Oct 28, 2009
118
what places actually do
4 wheel alignment?
if kwik fit dont.
thats pretty much par mr trye and a few other trye places that actually do trye fitting around my area lol
aterro
Banana Bomber
Oct 28, 2009
118
venner for the alignment side of it or fitting?
aligment was easy paid 45 sniffs.
they did toe,camber, and few other bits which i have forgotten.
he gave me a graph of the tracking also.
fitting was easy. i personally thought the fronts where easier to do than rears. its just all bolts.
if u need any help just drop me a pm
joop200789
330
Barnsly
i fort you couldnt adjust the camber on ibiza without buying extra's but tbh i never looked under a mk3 so i coulde be wrong, i know it cant be adjusted on mk4's without more modifing
venner
Drives Ibiza Cupra T
Apr 21, 2009
197
Near Bristol
Yeah a place near me will do it for £50 so about the same.
Also where did you get your top mounts from? Seat?
If so have you got part numbers and cost as i need to get them to make it easier to swap over.
deanomx206
anyone got a photo or diagram of all the bits from the suspension leg set up?
having trouble getting a diagram from seat!
venner
Apr 21, 2009
197
Near Bristol
http://www.vwspares.co.uk/ibiza99_suspension.php
take alook at this venner.
i had new top mounts with my coilovers as i bought them second hand.
Thanks for that link
Is it just the front that i will need top mounts for so 2 of these:
http://www.vwspares.co.uk/product_info.php?products_id=179
Or will i need 2 of the bearing aswell
http://www.vwspares.co.uk/product_info.php?products_id=180
Will i need to get anything for the rear?
Sorry if i sound abit dumb but just want to make sure i get everything i need at once so that they are easy to fit without having to use any of the old bits.
ahmadabdeen
well i just want to know if the golf MKII coilovers will fit the seat MKIII ??
