Thanks Tim would be great to arange that.
Kevh i have alway's been told once the butterfly has been moved it will knock it out of sync and cause it to play up ?? I didn't realise that you could clean without disconecting it ??
yeah give me a shout when you want it doing. it only takes 2 mins
Problem Solved.
Well after a week of the runing it and with the weather being cold again i can now say the problem is fixed.
I took the intercooler hose off and looked at the throttle body to find that it was dirty. After a good clean with carb cleaner and a small brush put it back together did the the reset job done.
The car is completly different to drive I can't beleive the difference it made. Well worth doing as a matter of course. Thanks for all the advice and a big thanks to wolvotim and his vagcom :clap::clap:
