Come home function
Deano3
86
Hi everyone I have switched on the come home/leave home function but nothing happens , is there certain requirements that need met ? I have just set up the reverse so mirror dips but struggling with this function, I don't have auto on lights so how do I get them to stay on for desired amount of time ? With ignition off if I switch lights on they flash for a second then go off I have 2015 fr with tech pack
Any help appreciated
Thanks dean
Sent from my SM-G930F using Tapatalk
Deano3
86
Ah okay thanks so even though says on car display it actually doesn't work at all ? In manual says something about it without auto function but thanks for that anyway glad I asked
mrratty
186
Others cars I've had (not vag cars) you flick the flash lights lever and the lights come on for 30secs
dw911
1,036
7
I think if you don't have auto lights you only get the coming home lights, remove ignition key, pull back on the high beam stalk for a couple of seconds and release, the headlights should stay on for 30 seconds then go out.
Must type lean to type using more than one finger, two people have replied whilst I'm still tapping away :D
toplad
93
you can code coming home lights with VCDS to come on when you unlock the car without auto lights
its done by coming on with the interior light
nice i was missing this from my mk2 fr+
can this be done with odbeleven?
Deano3
86
What exactly is this obd11 ? Obviously I know what the obd is is eleven just a software upgrade or something and alloys you to get into more systems etc and is it already in the car software just need laptop etc to access it ?
Thanks dean
chrisRibiza
1,194
51
Thanks dean
Android app to allow you to do certain software mods....
https://obdeleven.com
