Dmoe
126
Hello i am looking at getting a standard set of brakes for front of my LCR 2004 dont need anything amazing i only drive this car on weekends and never hard so i just want something standard ive had quotes for EBC Stuff and Pagid stuff the helpfull guy from Awsome recomended Pagid disc and a Tarox pad would you be happy with this setup? or can you recomend anything else? thanks
Hi, if you're not driving that hard, then most 'standard' off the shelf stuff from gsf is good enough, what you've been quoted for will pribaby do the trick also.
I know the ferodo premier pads are pretty reasonable, (cost/life span and quality) but I've never fitted them to a leon Cupra/r
Reece
I've just done the fronts and rears on my cupra r and I'm glad I replaced the pads with ferodo ds2500's on the front with drilled and grooved disks and pagid's on the rear. I can honestly say its worth it, I was working with the logic that there's no point having a fast car if you can't stop it lol.
yeh i carnet afford to spend a fortune on new brakes as ive also got service new battery and 4 new tyres to purchase so as i dont use car massivley and never hard look for cheapest but best i can get... anyone used Mtec discs and Mintex pad set up?
I can appreciate that, I don't drive a massive amount myself. I've seen average reviews of Mintex, but I guess if you're on a budget you want to find the best of a cheap bunch. I think you can find OEM disks for fairly cheap?
so i have a choice atm:
Mtec drilled and Grooved front discs and mintex pads £160
EBC Ultimax standard discs and EBC Ultimax standard pads £170
or
Pagid Discs and Tarox Pads £150
Which would you buy
I have the mtec drilled and grooved with mintex (on a TDI150 diesel) and they are better than the OEM discs with pgid pads. There is definitely less brake fade and I actually got the whole lot for cheaper than OEM.
Hi
From my experience with the brembo brake set up they dont like the mintex pads they constantly squeek. I would go for something like the euro car parts pagid disc an pad. Or similar.
8416229783
