RichN
Collecting Rings
Jan 29, 2005
533
Oxford
www.oxford7s.net
Hi folks,
Just got myself a Connects2 Aux adaptor tonight, and unless I want to run it attached to the end of the changer cable in the boot (which I don't!) I'm going to need a shorter CD changer cable. I assume that's correct.. what has everyone else done... and where is the best place to get one?
Getting impatient to get my connects2 box working now!
Rich
chrisbond69 said:
ah so could you use it to run an amp to power some better build speakers
No, all the devices I listed are devices which output audio to the head unit.
If you want to use an amp, you need either an amp with high-level inputs, or a converter (from autoleads) to convert from high level inputs (from the speaker-outputs built into head unit) to low level Phono/RCA line level inputs for the external amp.
Cheers.. I tried them but they can't help, but they suggested running a phono cable all the way back from the boot to the head unit and leaving the connects2 in the boot. I really don't want to do this..
Does nobody have any advice?
Where do I get the cable between the head unit and the cd changer - as short as possible - and possibly from a Leon..
I've tried Seat (two garages) both took a fair while to understand I meant the changer cable, and neither stock them. Both seemed confused as to why I would want one, and had never had a request for one before. Neither have been able to help!!
