Richie180
What is the fuse for, Which haynes manual do i buy to cover the seat leon?
think you must had some water in there? must have caused a shock and blowing the fuses.
is the battery suppose to be covered up?
yeah the battery was covered i removed the cover one day looking around and found this.
What is the fuse for, the car runs fine, if i remove it will it reset things?
ok guys which haynes manual do i get to cover the leon?
as the inside looks like an audi a3?
yeh this is the main connections for whole cor. You would need to change the whole box. Upon fitting the new box and connection. add some copper grease to help main the connectors.
The leftmost 30A fuse is S180 and is for the radiator fan low speed setting. Replace it, and if it keeps blowing you need to have your fans looked at.
Is the fusebox damaged, or is it just the fuse that has disintegrated?
There is no Haynes manual for the Leon or the Toledo. The nearest is for the Mk. 4 Golf, this one
http://www.haynes.co.uk/webapp/wcs/...ctId=13241&langId=-1&parent_category_rn=14543
or this one
http://www.haynes.co.uk/webapp/wcs/...ctId=30103&langId=-1&parent_category_rn=14543
:D
