Nov 2, 2004
9,334
South Wales
Just a quick question, when then afterun pump is working can you see coolant dropping in to the header tank through the top hose?
Just trying to work out if my pump actually works as I can see any evidence of it apart from the noise.
Thanks.
You can feel it shifting the water around if you hold the pipes when it runs
Mines so wiered only works now and again normally when cold and not needed
Mine started to do this, then eventually packed up altogether.
Looked in the fuse box on the battery and the fuse was melted, gave it a wiggle and the pump started working so i put a new fuse in, common problem with this fuse melting!
Not sure if you see it through the tank but as above you can definately feel it in the pipe
Mines packed in along time ago, Got a pump from an Ex police car ( omega im sure ), Then the fuse melted, Changed that for one from a Octavia
I would bloody hope they dont get blocked with anything as its pumping coolant round the turbo, Why not take it off and have a look at it, There pretty cheap from the scrappies if its broken.
I took my old one appart and it was filled up with what seemed like fine metalic dust, so I think they do wear out,
This is actually inside the motor not in the pipework btw
