low coolant temperature fixed
Finally got the car sorted today. Car went back to the dealers, they had it for day and a half. Collected it today - fixed. Everything seems to back to "normal" quickly reaches 90degC and stays there rock steady. Oil temperature 100degC.
Big job apparently to replace the thermostat valve assembly. They had to de-pressurise the air con as well. Glad I didn't have to pay for it!
Amazed at the time its taken to admit the problem, get the parts and get it fixed.
Also amazed at how much the low temperature running affected the fuel consumption.
In between visits to the dealers blanked off the grille, like we used to in the old days, kept a check on the coolant temperature, ran about 80degC and this practically restored the fuel consumption to pre fault levels.
If you get this problem insist that the coolant thermostat/valve is replaced.
car has been faultless for the first 18 months of its life.
