Coolant / Antifreeze
ski_tzo
96
Newtownabbey, NI
I need to top up my coolant but as i have only had the car 2 months I dont know what type of antifreeze has been put in it and dont want to mix them.
Is it a simple job to replace the coolant in the ibizas?
How many litres do i need?
And while im at it what should the temperature gauge show? ( all my other cars have just had a blue and red gauge but ibiza has numbers from 60-90-120) Hope this makes sense
If theres a guide knocking about that would be good :whistle:
Damoegan
Sir Bob,a geordy legend..
Oct 15, 2007
8,993
Newcastle
Dont put the blue stuff in mate, its the wrong stuff. You need VAG approved G12 long life stuff (pink).
You can get it from and motor factors or any Seat/VW/Audi/Skoda dealer.
andycupra
status subject to change
easy job.
on leons, at the bottom nearside of the radiator there is a tap for draining coolant. so no tools needed.
Id expect the ibiza to be the same.
when you drain it have the heater on so the coolant in the heater matrix gets changed also.
VAG group cars need VAG approved coolant, which is commonly G12. - available from any VAG dealer. Id expect you to need two bottles of this, which you then dilute to 50%. (so for each bottle of G12 you put in you put in another of water). Its a good idea to pre-mix the coolant before adding to the car to ensure you maintain a 50% mix.
most people will say you need 4 litres, including most dealers. i have found that if you drain it properly then you may need a little more. (1.8T).
The system should self blead when you re-fill.
You can get blue or green stuff that meets VAG specs, but i see little point as this stuff is a 2 year change. The pink stuff is a 5 year change. G12 from a dealer is red/pink.
If getting to a dealer is a real problem, (remember any VAG group will be able to sell you G12, so think skoda, audi, seat, VW) or im sure GSF/ VAG parts places will have it also. Then halfords do sell coolants that meet VAG spec. But you will need to ensure you get the right stuff.
The temperature guage as you say has figures on it. You should find that the coolant temperature sits at 90 when it has warmed up. It should barely move from this point.
A very short guide would be:
Jack car up and use axle stands to be safe.
Locate drain tap on bottom of radiator. (you will probably need to remove any undertray for access).
Get suitable container to collect old coolant.
Take cap of coolant expansion tank.
Put container under drain tap, turn tap. (of attach a short length of pipe to the tap if access for container is difficult).
You should find the coolant freely drains from the system. You can stop the slow by turning the tap at any time. (if for examples your container is not big enough).
When drained ensure you return drain plug back to 'closed'.
Re-place undertray.
Take car off axle stands and lower.
Get new coolant, check if its pre-mixed or needs mixing to the correct 50/50 split of coolant and water. It is important to get the correct mix.
Poor the new coolant into the expansion tank. Until it stops filling.
Then start engine, you will find the coolant level in the expanion tank falls and you should top up the coolant is it falls.
Put the heater on in the car to ensure a complete circulation of the coolant system.
Leave car running for a few mins and top up the coolant as required.
Job done.
Although i would recommend taking the car for a drive until it is up to operating temperature. Check the coolant level a few times until you are confident all is well
let us know how it goes.
loveturbopower
187
Frome, Somerset
if you open up ur expansion bottle (obv with engine cold)lol u should see what colour yours is already, thers only blue, red and green as far as i know but i dnt think u can use the blue stuff, i use red.
andycupra
I think mine usually sits at 60 and occasionally goes up to 90 but then back down again :confused:
thats not right.
they should start at 60, (which i think is the lowest reading). Then after a short preiod the temperature reading should increase to 90, where it should stay. Fans shoudl come on if it only moves a fraction above 90. It should not go back down to 60 once warmed up. - only if the car is parked and driven again later.
If its doing this, then you may have a thermostat problem, temp sensor problem or something else.
andycupra
wel it could be the thermostate, temp sensor, sender or gauge. No easy way to find out as far as im aware.
Thermostat or temp sensor would be the most likely id think. I cant guarantee it, but id try the thermostate first. I assume it tends to go below 90 when taking it easy but on the move. Then may rise when in traffic etc?
nice to see you appreciated the guide... ;)
Dan1.6
1.6 Power FTW!!!!!!!!
Sep 26, 2008
981
Chesterfield
i think its more likley to the thermostat
i had a problem with the sensor on mine so i changed it and mines doing the same as yours does it only reach 90 on tickover?
ski_tzo
96
Newtownabbey, NI
Thank you for the guide Andy i just havnt got a chance to put it into practise yet!
Are thermostats hard to fit, i see a few on fleabay but if stealer wasnt too bad id rather get genuine part
Dan1.6
Sep 26, 2008
981
Chesterfield
its easy to do il take a picture of were it is on my 1.4 for you if thats any help and its just a small clip that you have to remove and you will get a slight collant spillage.
Dan1.6
Sep 26, 2008
981
Chesterfield
okay il try and take a picture tonight when i get in from college il take a picture of what the sensor looks like as well if it still have the old one lol
