hi the radiator fan on my cordi 99 1.6 , those not spin all the time , well I never sin it spin , I was wondering if it was normal ?
thank for your suport
the temp meter does not work properly, its always on red , I changed a few things, and with my mechanic we drove the car the way it was, and measured the water temps and it was normal. some times it show the right temp and some days not . thanks for your quick reply!!
no not the therstat but the temp sender, if them water temp is ok as you have checked it but the gauge reads high int. that would be the first thing I would change.
it should be a 4 pin conector that is screwed into the head, follow the water pipes from the rad and you should find it.
