Correct parts to replace LCR clutch?
GJF47
405
Hirwaun, South Wales
My clutch has been slipping in 6th ever since it was mapped but recently started slipping in 3rd 4th and 5th so its time to get it changed. Looking at this from carparts4less, would there be anything else I need to order and are these the correct parts?
http://www.carparts4less.co.uk/cp4l...b0bf119ba29a29c034c4fc545607ead63565&1&000069
http://www.carparts4less.co.uk/cp4l...53898dd886e807cdced6560dae85d31558fd&1&000134
After doing a bit of research it seems that this would be fine with a Stage 1 REVO with around 300lb-ft but I want to make sure before ordering.
heggie
212
Ross-on-Wye
Looks like the whole lot you would need. Had mine changed about 3 months ago now and it was the DMF that was at fault. Makes more sense to change the whole lot in one go save having to have the box back out later on for something else
GJF47
405
Why do you want to replace dmf hiw many miles is your car on
Sent from my C6603 using Tapatalk
Just hit 105k
Do I need to order anything else apart from the above?
GJF47
405
Br!dges
753
Wales
Cheers mate :)
Need it sorted this week as it's getting worse. Struggling to put power down in 3rd and 4th now.
http://www.carparts4less.co.uk/cp4l...d2e5450ddc9c201bc349ff522174ab5a9a6120&000468
Not really worth it for what I am running tbh.
That's them dude but don't do what I did and put 6 in as quantity thinking id get 6 individual bolts because..... i had 6 packets with 6 bolts in each packet lol!
In my defence the description is misleading!
Are you getting some one to fit? If you are id get them to change the master cylinder and add the shim to shaft on side of gearbox (if you have the correct box)
