CR170 Manual Gearbox Oil/Fluid
t0m_t0m
59
9
Hull
Hello, I've read some conflicting information on the Internet and here as well.
Does anyone know for sure what the correct stuff is to put in the 6spd manual box of a UK spec 2009 FR CR170 TDi?
I've read 75w80, 75w90, 75w GL4, amongst other things, then I've read you can't mix synthetics and non-sythentics, and finally that some folks have experience "notchy" gear changes with oils/fluids that other have recommended.
I know that the oil/fluid is said to be lifetime, but with lifetime guarantees only being around 60k for cars surely a change would be in order now I'm at 100k.
I'd rather not use the dealer as I've heard they charge around £30 a litre, whereas you can get OEM type stuff form the likes of Feb Bilstein for half that i just want to be sure I'm buying the correct grade.
