Creamy brown Mayo but no coolant loss?
4/4 dirty dervs
243
kent
my cars been off the road for a couple of months. I've been starting it occasionally manoeuvring it around fixing odd faults and going for the occasional blast and back. Today I took the oil cap off to have a look about because it seems to be leaking oil out the rocker cover all over the place. Where I noticed a slight bit of milky substance , but under the little recess where the cap screws onto I found thick creamy brown stuff. Instantly I've sh*t a brick thinking head gasket. But the coolant is clean and the level hasn't dropped. Any thoughts?
Feb 6, 2014
1,323
Lincoln
I think these engines do leave a little mayo on the cap if not taken out on a run for a while. It's to do with the engine getting up to temperature. Mine does if I don't use the car much, doesn't appear if I give it a good blast regularly. Keep an eye on it, should be fine.
4/4 dirty dervs
243
kent
I'm keeping my fingers crossed that it'd not the HG! By the way does yours condensate a lot on start up by the way?
4/4 dirty dervs
243
kent
I won't lie, I had to google Italian tune up lol but ok I'll try not to fret until I give it a good run. and yeah same mine is quite excessive when it comes to condensation and acts exactly as yours does.
aaronb84
158
Brighton
Just to confirm when mine doesn't get used to much I also get the mayo. Nothing of concern. Also condensates a lot in colder ambient temps like we are having at the moment.
4/4 dirty dervs
243
kent
just had a quick look under the cap and its not like ive just opened a jar of hellmans like the picture posted above so hopefully is nothing to worry about.
josh-leonfr
74
Newcastle upon Tyne
I had this with my old Astra 2.0t Sri pretty common from what I read. Like mentioned above it's to do with short journeys and condensation in winter etc. Just keep an eye on your water to make sure it isn't anything serious though
SWANSWAY CUPRA Dealership
