When I have the cruise control on in my car there is no light displayed on the dash whereas a friend of mine has the Large mfd and his shows the symbol when cruise control is on.
I also have the small display and the symbol does not appear when I use cruise control, however when the sun shines on the clocks you can see the symbol on the speedo? Has anyone with the small display have this working?
Nope, I had a pre facelift 58 plate FR 170 derv with the large MFD and it had a green light on the dash. Sadly it didn't have a light for low shreen wash fluid.
If you can get access to VAGCOM/VCDS then go into the Instruments control unit and in the adaptions or coding menus there is a "cruise cont. display" that you may be able activate.
