Cupra 280 center muffler delete
benhella
48
I love my 280 but always though she was a little quite. I dont want to shell out for a full exhaust change. Has anyone removed the central muffler is it a DIY job? How much would it cost? Does it drone? And has anyone got any videos of what its like post removal?
Sent from my SM-G920F using Tapatalk
kiddo
ST Cupra
May 30, 2015
1,151
99
Lancashire
Someone on here posted they had removed the centre silencer for £48. I so want to do this as well for more grumble ;)
Raven
223
11
I've bought the middle section from a Golf Gti. It's the part between the downpipe and the rear muffler.
From the downpipe it's an easy job, just loosen the clamp holding the downpipe and catback section together. In front if the rear muffler you'll have to cut the pipe and then weld em together. Will leave the car to a local garage this Thursday.
Sent using my fingers
Raven
223
11
Result is mint!
Got a much deeper tone and the cracks from the dsg shifts are louder!
Raven
223
11
Should sound like a 290 or golf Gti. :)
All I got is my android phone but I can give it a try someday though.
jip
45
Sweden
www.youtube.com
Hey!
Did a thread about this a couple of weeks ago. Stillhaven't removed my middle silencer due to I wanna know if you get any annoying sound when cruising the highway or not. I want it to be silent when cruising, but louder when accelerating!
Raven
223
11
I think it's important to separate the middle silencer from the resonator.
I replaced 1 and 2 with 2a which came from a 2015 Golf GTI PP.
The tone is deeper between 1000-2000 rpm. No drone at all as the resonator is still intact. The exhaust pops/farts are louder and you can still here it pop going Wot and shift 4th to 5th near redline.
The job is a diy if you have the option to cut the OEM exhaust and then use a clamp to hold the two sections together again. If not you can leave it to any garage for the fitting.
Curtly
893
19
Essex
Anyone thought of doing this with the Fr? I had a look the other day and the exhaust system looks unnecessarily complex - a simple bypass of the middle silencer (there's 3!) Should make things alot more efficient and sound a touch better
jip
45
Sweden
www.youtube.com
That's really interesting!
But what exhaust is the one on the picture? Not an 280 i believe?
This is mine at the rear, I dont have the number 3 muffler..
Pic: goo.gl/photos/b6yZANDjTWqdnmQp8
Raven
223
11
You have an ST..
ST 280 and 290 have the same exhaust.
See below picture.
SC/Hatchback 280 has an exhaust as the picture in previous post is showing with 1 resonator and 2 mufflers. 290 lacks the middle muffler.
jip
45
Sweden
www.youtube.com
You have an ST..
See below picture.
Hmm... didn't even know that the exhaust was diffrent between hatch or estate! :)
Yes, mine looks just like this picture. Are you sure the exhaust from ST280 and ST290 are the same, then the ST290 must have smaller dual mufflers in the rear, due to no middle silencer (just a resonator). After all, it is a lot louder, without any MSD from factory!
Jesper
jip
45
Sweden
www.youtube.com
Ah ok I see!
And I found this video of ST280 vs. ST290 revving.. and it seems to be the same hardware, as you say :)
https:// youtu.be/AuX4JdVH3q4
mx5
30
Ireland
That's great info, thanks for posting.
I'm going to simply remove the centre silencer and join the exhaust with a custom pipe so I can re install the original exhaust if required without any cuts. It should be cheaper than buying part 2a too. I'll report back when I've done it.
Raven
223
11
The stock exhaust is 2 parts. Downpipe and catback. The clamps shown in above picture is unfortunate not there.. The whole system is welded.
