I thought I'd write about a couple of "issues" I've had with the DSG box on my Cupra 280 to see if anyone had experienced the same. I could be doing something wrong or expecting too much...or there could actually be a fault. I've done just over 6.5k miles in my Cupra now, so getting to know its quirks pretty well...(still absolutely loving it though!)
Issue 1:
In DSG sport mode, I find that the gearbox takes ages to change back up the gears when you take you foot off the accelerator. After over-taking or joining a motorway (or just having a bit of fun!), when I take my foor off the accelerator, the engine just sits at 5.5k - 6k revs for at least 5-10 seconds (with my foot completely off the pedal) before I usually stick it back into "Normal" mode to drop the revs back down again. It seems to take an age to do this automatically...but it eventually does. The other way to clear it (I have found through experimentation) is to just lightly touch the brake pedal.
Sport DSG mode obviously keeps the revs up to keep you in the optimal power-band for "sporty" driving and power on tap when you put your foot down, but it should not just sit near red-line with your foot completely off the throttle...surely?
Issue 2:
Occsasionally (again in DSG sport mode), there is a good half a second to a second hesitation changing up the gears under hard acceleration. With my foot to the floor, usually between 3rd & 4th, it occationally pauses for a brief moment, taking far longer than normal to change gear...causing the car to lurch forward then back again when it eventually finds the gear. I can only recall a hand-full of times when its done this...but it's far from a one-off. This is not after prolonged abuse (so it's not overheating or something)...I never drive it hard for any longer than a few seconds, I value my licence too much!
Anyone else experienced the same, care to share your experiance and/or advice?
Cheers guys!
Issue 1:
Issue 2:
Cheers guys!
