Maybe the Seat stealers have read your comments on here.... Maybe check your glove box for 'presents'Perhaps I should take it there then...
Interesting.. The technical document I have says its a software update for the airbag module, to stop an incompatibility issue with the gear lever! Either way, glad they're fixing it.
I did scan the document today, but forgot to email it to my home PC..
Can you post this up please mate? I have a chassis number for my new car and wondered if it was affected?
Cheers.
So my chassis number is VSS___5F_FR055***
As it's an FR and not an ER as you have detailed on the PDF does this mean it's not affected or is it just the last 6 numbers that identify it??? In which case it does fall within the numbers affected??
Anyone know for certain?
Yes, me. When accelerating hard my car sometimes refuses to change up a gear, leaving me bouncing off the limiter. Had the airbag light on all the way to work the other night, too.
I suppose I should be grateful that it works most of the time, though, I suppose, as no one has been able to mend it yet!
There's a recall just go in give them your vin and they will flash the update.The airbag light did clear, yes. And no, I haven't had the gearbox fixed. It only happens occasionally and the thought of a SEAT grease monkey ranting my car up and down a dual carriageway all day trying to replicate it is what puts me off getting it done! I'm just gonna live with it, I think...
