DoubleMind
Hi guys!
I have 2016 Seat Leon Cupra with DSG6 gearbox(DQ250) Car is full stock.
Now is 2000 km on odometr and i have a lot of errors in DSG((
When driving on 5 or 6 gear for example in manual mode and put throttle to full - clutch slipping... Look please errors. Problem in mechatronic or need change full gearbox + mechatronic? Have you ever seen this errors before? Gearbox shifting ideally. Errors only when you put gearbox from Parking to Drive. If you start car and selector still in Parking, no errors. If you put it to DRIVE - errors... Have anybody on this forum same issues with his car?? Anyway thanks for any help!
Errors:
Address 02: Auto Trans Labels: 0D9-927-770.clb
Part Number: 0D9 300 020 K HW: 02E 927 770 AQ
Component and/or Version: DQ250-6V MQB H53 4930
Software Coding: 0014
Work Shop Code: WSC 04742 780 00200
ASAM Dataset: EV_TCMDQ250021 001001 (SE37)
ROD: EV_TCMDQ250021.rod
VCID: 1D3A256D0C9911ABD7-8048
11 Faults Found:
21153 - Gear 1
P072C 00 [002] - Not Selectable
Intermittent - Not Confirmed - Tested Since Memory Clear
Freeze Frame:
21154 - Gear 2
P072D 00 [002] - Not Selectable
Freeze Frame:
21155 - Gear 3
P072E 00 [002] - Not Selectable
Freeze Frame:
21156 - Gear 4
P072F 00 [002] - Not Selectable
Freeze Frame:
21157 - Gear 5
P073A 00 [002] - Not Selectable
Freeze Frame:
21158 - Gear 6
P073B 00 [002] - Not Selectable
Freeze Frame:
21159 - Gear R
P072B 00 [002] - Not Selectable
Freeze Frame:
10731 - Valve 3 in Transmission Part 1
P174A 00 [002] - Electrical malfunction
Freeze Frame:
10732 - Valve 3 in Transmission Part 2
P174E 00 [002] - Electrical malfunction
Freeze Frame:
10657 - RPM Signal from ECU
P0726 00 [002] - Implausible Signal
Freeze Frame:
10906 - Cooling Oil Valve
P179D 00 [002] - Electrical Malfunction
Freeze Frame:
Everything is okay now. Every MQB car with DSG-6 have this errors when you check gearbox errors by VCDS, i just look it and afraid. Now i know thats normal for Cupra, Octavia vRS, GTI, R, S3 and etc when you check it by VCDS. ODIS have no errors :D
No, VCDS dosen't show these errors by default. But driving the car / having the car on idle will give you all these faults. Faults should be read with igntiotion on, not engine running.
How could they explain the dsg slippage?
