cupra-cupra R exhausts
t32er
hello ppl
does any one know if a leon cupra r exhaust (not manifold but from that back) will fit the cupra?? i know it looks a little diff but i dont know if it fits the same way
im sure i can make the back box fit its the midle pipes-box and cat im more worryd about
hope some one can help
terry
cordobabrendy
FOOORRREEE!
Aug 24, 2001
7,642
belfast
Dont skimp, the standard lcr ones will rust as its not all stainless steel, I went for a similar look but with stainless cat back powerflow, no rust and no problems since fitting more than 2 years ago now.
t32er
iv been offered a lcr one cheap but dont want to buy it if it ent guna fit.
the lcr back box should fit IF you cut the oem one off in the right and same place as the lcr one (if all cupra pipes are the same as mine - welded together rather than clamped that is)
does any one know the answer??
Avant4me
359
Bristol
LCR Box
Rear section should fit. PIPER used my car for their system and commented that the rear system was exactly the same. Turbo mountings in different places so the front half will be useless to you.
onapper
does anyone know of anyone who is selling a sports exhaust (turbo back, down pipe, sports cat...the works) for a leon cupra r?
james walker
cooling is the key people
May 24, 2007
5,121
retford notts
post a wanted in the wanted section, or look in for sale.
cupra r exhaust does fit but needs modifying as the exhaust cutout isdifferent on the r. it wont sit central on the cupra. but it can be done.
vwbassett
Joined the Dark Side
Aug 13, 2007
963
53
Surrey
I wouldnt do it as to get the old one off youve got to cut it right and then seal it properly when you fit it or remove it as one piece by dropping the rear axle and mine was ridden with holes after 4 years so it just wont last. Get a proper sports one that will sound better, last longer and weigh 5kg less!
Phillc
Love is....Yellow
Apr 23, 2007
4,170
20
Pershore, worcestershire
I dont like the twin tail pipe, it needed replacing i got the "R" one for £10 my mates a welder and i didn't have £300, but i am saving for the SS turbo back, not scriping if you dont have the money just making do with what i had.
