Cupra r antiroll bar
TommyD16
9
Hi guys. Been doing some searching online to no avail.
I need a new front ARB. Original or aftermarket I don’t mind if anyone has any links or is selling a one in good nic.
cheers
Thai-wronghorse
Self proclaimed Cupra R addict & butcher!
Dec 3, 2015
2,257
1,110
Kent
I have used ones available, stock fronts and an aftermarket rear.
Sent from my SM-S906B using Tapatalk
Jay20VT
The 'R' In CupRa
Jul 23, 2004
658
82
N.London
I lowered mine a couple months back with KW shocks and HR springs. Is it worth doing the ARB also? What will I expect, ride wise?
andylong
494
An anti roll bar will only not affect ride if both wheels on the axle rise or fall together.
Under any other circumstances the effect will be like having stiffer springs on the loaded wheel.
There's no play in roll bar parts so it doesn't take much for it to have an effect.
The stiffer the bar and suspension the more noticeable it will be together with whatever mounts you are using.
In a straight line on a relatively smooth road with a roll bar that's not too stiff you won't notice it.
The correct roll bar is probably the best suspension upgrade you can do.
If you stiffen up the front you'll increase understeer and stiffen the rear tend towards understeer, but that's more handling than ride.
Reactions: Rich.T and Jay20VT
