Cupra ST Mk3 2018 DSG6 vs Cupra ST Mk3 2019 DSG7... help needed please!
SitdownandhaveaCupratea
133
84
Hi guys,
This thread is following on from my previous topic which you gave great feedback and responses to, as I believe it deserves separate focus https://forums.seatcupra.net/index....zing-and-i-have-some-questions-please.447084/
Basically today I went to look at a fully loaded Cupra ST 300 DSG6 2018 and apart from the frankly awful Beats sound system I was very impressed, it was a beautiful car with a nice interior. I then went to the dealers desk to talk over the fine details and during the conversation just happened to notice that some more Cupras were coming in over the next couple of weeks, one of which was a 2019 model. I then asked what the difference was between the 2018 and 2019 was (I could see him groaning inwardly that I had got distracted from the 2018 car that he undoubtedly wanted to shift asap) and he said it was basically a newer DSG7 gearbox, a new colour grey paintwork and a copper coloured SEAT badge on the front.
Clearly the badge and paintwork don't matter but what really does and that I need to give serious thought to is the potential upgrade to a DSG7 gearbox. The problem is, if I want to reserve the 2018 model then I need to commit to it early next week.
So, my questions are...
  1. What do you guys think the positive/negative impact of a DSG7 gearbox will be on performance and economy on an ST300?
  2. Do you think that an ST300 2019 represents a better buy than an ST300 2018 purely in terms of residuals (ie: anything significant)?
  3. Anyone know of any other differences I may have missed in terms of standard or non-standard kit between the older ST300 2018 and the new ST300 2019 model?
Thanks in advance for any advice you can give! :)
Damo H
4,707
2,816
Car Length In Front
Odd that I was just looking at the Golf R Estate performance and mpg vs the Cupra ST 300 Carbon Ed. It was because evo magazine said the torque on the Carbon ST was 20 Nm down on the R. That is not the case, however it did make me look at the mpg.
Now I know the Golf R has 10 more hp and is a different shape, but look at the mpg comparisons of the 7 speed 310 R and the 6 speed ST carbon:
Golf R Estate 310 7 speed:
Power: 310PS
Torque: 380Nm @ 2000rpm
Urban: 31.7mpg
Extra Urban: 45.6mpg
Combined: 39.2mpg
Cupra ST 300 Carbon Edition 6 speed:
Power: 300PS
Torque: 380 @ 1800-5500rpm
Urban: 31.0mpg
Extra Urban: 46.3mpg
Combined: 39.2mpg
As I do most of miles my miles on the motorway, it seems based on gearboxs the 6 speed is better. Or that the golf is significantly less aerodynamic!
black_sheep
1,251
587
In response to the differences, I would look at the 'who's ordered a cupra?' sticky thread at the the top of the page, and this one here:
https://forums.seatcupra.net/index.php?threads/my19-leon-cupra-details.446850/
From what has been discussed, the 1-6 ratios on the 7 speed box are closely matched, with the 7th gear being an overdrive. The DSG7 has been fitted to the Golf R since the Mk7 was face-lifted - I would assume that the ST300 has the same DSG7/engine map as the Golf R to ensure homologation could be achieved.
One of the positives for Swiss/German users will be the Gasoline Particulate Filters fitted to the engine for entry into some of the more restrictive low emission zones?
black_sheep
1,251
587
Now I know the Golf R has 10 more hp and is a different shame, but look at the mpg comparisons of the 7 speed 310 R and the 6 speed ST carbon:
Golf R Estate has also been pegged back to 300 ps post WLTP.
Oldbutswift
284
91
Interesting,but the fact that the top gear is an overdrive on the 7 speed doesn't really stack up with the mpg figures given in Damo's post .
In other words, you would expect the higher gearing to mean better extra urban figures.
Are the final drive ratios the same?
(I have to say that in my family there is an S3 and a TTS,both have the older 6 speed dsg and their top gears seem high enough for this country,but perhaps not on an unrestricted Autobahn,which I haven't tried!)
Damo H
4,707
2,816
Car Length In Front
The VW Website is still quoting 310.
So either it hasn't, or those above figures I've quoted are before the more restrictive exhaust.
If that is the case then I can only assume the golf is less aerodynamic than the Leon to explain why the newer 7 speed gives a lower mpg than the Cupra.
Damo H
4,707
2,816
Car Length In Front
Until we 100% confirm it, remember I'm potentially comparing a none WLTP car (carbon edition ) with the WLTP car (R). Will just have to see when we get official figures.
Reactions: Oldbutswift
Oldbutswift
284
91
Roughly,so I may be wrong,I have looked up some figures that suggest to me that a 6 gear Cupra 300 does 27 mph per 1000 revs in top whereas a 7 gear Golf R 310 does 32 mph/ per 1000 revs in top.
However all the lower ratios on the 6 speed are higher.
So the 7 speed has lower ratios which should help acceleration and has a higher top for lower revs cruising and economy...but more frequent gear changes of course.
So the 7 speed box is the more advanced design and theoretically better,but in the conjested and speed limited UK its advantage over the 6 speed could be marginal.
Damo H
4,707
2,816
Car Length In Front
Without the thread descending into a bun fight like your last one (not your fault, certainly not mine but responsibility of one other individual who took offence at me putting forward the R estate!) this review says the 300 ST doesn’t have the 7 speed box. https://www.evo.co.uk/seat/leon-cup...edition-review-better-than-a-vw-golf-r-estate
That’s because it’s the Carbon Edition which is based on MY18 where as the new cars coming referenced by the original post will be a MY19.
Reactions: xyz
Oldbutswift
284
91
That's the Carbon Edition which is a run out 2018 model.
It will only be 2019 models that move on to the 7 speed.
EDIT sorry,missed that Damo beat me to it!
Reactions: Damo H and xyz
133
84
Power: 310PS
Urban: 31.7mpg
Combined: 39.2mpg
Power: 300PS
Urban: 31.0mpg
Combined: 39.2mpg
Yeah I guess in real terms the mpg differences will not be majorly significant because of one extra gear at the speeds 99.9% of peope will be travelling at.
Thanks mate I looked at this as you suggested but there is not much in the way of information about the real differences (in so far as anyone can know at this point), it's more people complaining (rightfully) about the car being different to what they ordered.
Hmm interesting... I haven^t see any complants about the DSG7 on the Gold R, have you? In terms of any negative impact, I mean.
I would guess 6 speed is more than enough for roads in old blighty, even motorways are pretty slow.
Interesting. Considering I will be doing a good mix of mountain twisties and cruising at 100-120km/h I guess a 6 speed DSG does the job.
I guess now it is just a case of how much the re-sale value will be affected buying a brand new 2018 model at the very point that the 2019 comes out.
And such a shame Seat Sound appears to be discontinued... :(
Damo H
4,707
2,816
Car Length In Front
I don’t think the 2018 model year will lose out to much to the 2019. I know it will have the gearbox, but it will also have the copper and less spec.
As for Seat Sound, my Carbon doesnt have it. But it will after its retrofitted. Unlike Beats it’s only 2 extra speakers, no additional amplifier.
Oldbutswift
284
91
In the U.K. cars are mainly valued on their year of registration,not the model year,unless of course there is a total change of model,but with the Leon the difference amounts to just a "facelift".
So I would say 2 or 3 years down the road there will be little difference in the value of a 2018 or a 2019 model if both are put on the road before the end of the year.
Personally I would much rather have the earlier model if there is a significant price saving over a 2019 model because that amounts to a chunk of depreciation you have avoided on day one.
133
84
Well, I spent some hours over the last couple of days reading about the new DSG 7-speed gearbox in the Cupra 2019 and it seems to be the DQ381 which is a wet clutch model use since 2015 or so in many mid-high performance VAG cars. Feedback seems to be that:
Positives:
  • The performance is good overall with quick shifting
  • Noise and economy improve when cruising due to the 7th gear
  • A remap of the software dramatically improves performance
Negatives:
  • Until warmed up, it can be clunky switching from 2nd to 3rd and sometimes 4th to 5th
  • Sometimes switches down from 7th to 6th at inopportune moments when easing the foot off of the gas pedal
Sources used:
It is just such a damn shame that Seat are controversially changing the styling for the 2019 models as otherwise I would be sold. :(
Damo H
4,707
2,816
Car Length In Front
Positives:
Negatives:
Sources used:
Honestly think you should get the 2018 model. The 6 speed is a good box and you don't have to worry about the styling.
It reminds me of Eddie Jordan talking about Yachts :O He was asked about Ferrari's ridiculous expensive Yacht in Monaco. He said something along the lines of.
"If you sat on a 10 million pound yacht, and your unhappy because someone has a 500 million pound yacht to the side of you, there is something wrong with you, not the yacht."
And the the 7 speed gearbox isn't THAT much better than the 6 ;) Plus the 6 speeder is on a none WLTP 'bodge job' car. Remember these engines were never originally designed around the new WLTP regs. So I'd say your safer with a MY2018 car.
