Indeed! My vag specialist recommended a 2nd hand known good box with warranty rather than recon which was £1200 new was £2000 the 2nd hand was £400ish and warranted!
Cheers, oil may have been a solution, but it looks like it is the diff bearings that have gone. Booked in tomorrow. Been advised that a rebuild of the 'box may be possible.
May as well have the clutch and flywheel done at the same time.
No single mass flywheel available I am being told so mega bucks dual mass one to add to the grief
You can guess what my Christmas present is this year
Yeah deeply p!ssed off, but hey ho!
The price I have been quoted was around £440 incl VAT for the DMF and clutch and I am just holding my breath on the 'box and 'diff.
Bit like you if I had some more cash I would have have gone for an LSD. Maybe next time....
Got the report back from the gearbox man...
One tooth broken from the crown wheel which clattered around and damaged 5th & 6th.
Does beg the question... Is this an engineering issue? Never had a diff break before and I am running the car stock so should be engineered to deal with the torque.
So...
£550 + VAT later....
Still cheaper than a recon 'box or a new one, and no worries about the history of a secondhand 'box either.
So far can't fault the service of my local specialist.
