danlangley22
Hi all,
I have a 54 plate leon 1.6 16v, I shattered an idler tensioner and bent all eight of my exhaust valves, before hand the car ran perfectly I stripped the head off had it crack tested and skimmed and replaced the valves. After I started the car for the first time it was smoking like a steam train, I took it apart again and and replaced all of the valve stem seals, ran it again and still smoking also it was melting spark plugs causing a misfire, and when I say smoking I mean the entirety of its oil in 3 days ! I checked all of the breathers and checking for crank pressure, all cylinders are producing 240 psi of compression and I've done a test with wd40 on top of the pistons and it sits there with no movement, there is slightly more play in the exhaust valve guides (the side that the valves bent) than the inlet side, but no cracks! I've now been told that These have nikasil coated cylinders and they can go, and that my problem is bottom end ? After spending 500 squid already I don't want to throw any more money at it, any advice would be appriciated on what the problem could be ( I thought It could only now be valve guides) and am considering doing an engine swap , I believe my engine code is BCB but is there any other engines I can put in and do I have to alter any ecu maps etc. whatever happens it's going when it's fixed , i just want a cupra now lol.
Many thanks in advance
Dan
If your compression test reads good then its probably not going to be the bottom end, normally a bent valve would wreck the guide, if you didn't change the guides and the valves were quite bent then its possible the oils leaking past the guides..... If it didnt use oil before you bent the valves and now it does it would indicate something in the head.
Are all the plugs getting oily when you take them out ?
Or maybe the headgaskets not sealing, did you check the head with a straight edge when you had it apart ? My monies on the valve guides being oval and leaking oil past.
Good luck.
Yeah the plugs get all oily after running for a little, causing it to misfire, no smoke at all before hand the head was skimmed and crack tested by a professional company, and now I have done valves, stem seals checked all breathers In my opinion it has to be guides as like you said it shouldn't be bottom end if I'm getting 240 psi in each cylinder ! Cheers
