I had mine checked on vag-com, this is the fault code.
1 Fault Found:
16804 - Catalyst System; Bank 1: Efficiency Below Threshold
P0420 - 35-00 - -
I had the emissions checked to make sure the cat is ok, all readings were well below spec so the cat is ok.
I have a full exhaust system with high flow cat so might space out the second lambda as some of the guys are doing here...
http://forums.vwvortex.com/zerothread?id=1366095
Neil.
Same fault as I have, one of the lads at work ran a full scan for me.
I'm off to see Bill for Custom Code phase 2 tomorrow, I believe this can be mapped out / switched off with phase 2.
The bliming Amber light has returned on my LC too!
